Use this procedure to display the I-SID-to-VLAN assignments advertised by an FA Client or an FA Proxy, to be supported on the FA Server. These assignments can be accepted or rejected by the FA Server. An assignment that is successfully accepted by the FA Server results in the creation of a Switched UNI I-SID on the interface.
The following example displays a sample output for the show fa assignment command.
The state of I-SID-to-VLAN assignments on a client or proxy device is pending until it is changed by the FA Server to active or reject.
Switch:>en Switch:1#show fa assignment ======================================================================= Fabric Attach Assignment Map ======================================================================= Interface I-SID Vlan State Origin ----------------------------------------------------------------------- 1/1 2 2 active proxy 1/2 3 3 active proxy 1/2 4 4 active proxy 1/3 5 5 reject proxy ----------------------------------------------------------------------- 4 out of 4 Total Num of fabric attach assignment mappings displayed -----------------------------------------------------------------------
Variable definitions
The following table defines parameters for the show fa assignment command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
